Hello Guest it is October 20, 2026, 03:05:16 PM
Author Topic: MDI INPUT  (Read 41906 times)
Re: MDI INPUT
« Reply #10 on: August 05, 2013, 09:39:22 PM »
Just a sample of a Music Roll Master.  It will create the Gcode file and Preamble header(safety) then you can create a punch code for each line to be punched.
0-1  Zero no hole , 1 hole
The program creates each line to be punched as a group driven by the G81 cycle with the locations following. Each line has a number (N1,etc)
You can see the Gcode created for each line and see a tool path for the positions.
Each punch position is also denoted by the Note it represents  (A2   A of the second octave).
It is just a start, Let me know if it is something you may want to try.
« Last Edit: August 05, 2013, 09:41:35 PM by BR549 »
Re: MDI INPUT
« Reply #11 on: August 06, 2013, 03:19:00 AM »
TP
Thanks very much
I would love a sample to try ;D
Graham
Re: MDI INPUT
« Reply #12 on: August 06, 2013, 12:43:14 PM »
HERE is the latest screen shot AND a beta copy of the Wizard(;-)
Re: MDI INPUT
« Reply #13 on: August 07, 2013, 07:59:25 AM »
TP
Thanks.
Will play around and see what I can achieve.
Graham
Re: MDI INPUT
« Reply #14 on: August 07, 2013, 12:13:23 PM »
IF that does not work for you we can try something else .
Re: MDI INPUT
« Reply #15 on: August 07, 2013, 05:13:47 PM »
I found the music SCALE for the rolls and updated the screen.  I also updated the Gcode output to match the scale.
There are other ways to do this as well if this does not work out for you.
Re: MDI INPUT
« Reply #16 on: August 08, 2013, 03:53:48 AM »
TP
Have downloaded latest version and am testing it.
How do you vary the distance between notes from the edge of the roll as it seems to be incremental at one inch?
On my music organ it goes 10mm,9mm,9mm,9,and then 6 for the rest of the 20 notes.
Returning to mach 3 button is problematical.
There will be more!!!!
Graham
Re: MDI INPUT
« Reply #17 on: August 08, 2013, 11:50:21 AM »
The step over distance for each note on the scale is set by code it can be changed to anything you want.
The return to mach is a standard CB call. What is it doing there?
Re: MDI INPUT
« Reply #18 on: August 08, 2013, 02:15:40 PM »
TP
It hangs up on generating toolpath before it returns to Mach 3.
Graham
Re: MDI INPUT
« Reply #19 on: August 08, 2013, 02:46:29 PM »
Are yoou by chance getting a watchdog error . Here it takes about 10sec to reload from the wizard. But it have never failed to reload. I have watchdog turned off in genconfig.
