Hello Guest it is October 05, 2026, 02:47:45 AM
Author Topic: Rotational axis endless rotation  (Read 12388 times)
Offline KMX
  •  12 12
« on: July 30, 2013, 03:27:11 AM »
Hello!
I have a 4 axis milling machine (4th axis is rotational) and I would like to know how to make rotational axis to endless rotation (to work as lathe spindle).
Regards
Re: Rotational axis endless rotation
« Reply #1 on: July 30, 2013, 05:45:18 AM »
All depends on the setup of your normal spindle but likely the easiest way would be to just set up a new profile for when you want to use it as a lathe.
Offline KMX
  •  12 12
« Reply #2 on: July 30, 2013, 06:07:26 AM »
No, new profile is not good option, because I need both at the same time. Is it possible to create a profile for lathe (rotational axis is main spinlde) and then use milling spindle as "live tool"? Which M-code starts live tool on lathe?
Another option; is it possible to manually set value of analog output and then write a macro?
Thank you, Denis
« Reply #3 on: July 30, 2013, 07:22:57 AM »
No live tooling option in Mach.
Do you have an analogue output? If you have something that can output an analogue signal then a brain or macropump could possibly be used.
Offline KMX
  •  12 12
« Reply #4 on: July 30, 2013, 01:35:42 PM »
CSMIO/IP-S has two analog outputs.
« Reply #5 on: July 30, 2013, 03:25:34 PM »
Ok you should be able to do it via a macro or a brain or whatever you want. I am not sure what the modbus address is for the analogue outs, cant recall seeing it in the manual so you may have to email CS/Lab and ask.
