Hello Guest it is November 28, 2026, 02:12:02 AM
Author Topic: No Y axis movement from G code  (Read 35278 times)
« on: July 28, 2013, 10:58:45 AM »
Hi All,
I hope you can help!
I don't seem to have any Y axis movement when i run a program to cut.
I can jog and everything works and even run a drilling program and everything works but when i run a cutting program the head will move to the correct starting poiint using x,y and z axis but then wont move the y axis when cutting?
Thanks in advance
Gav
Re: No Y axis movement from G code
« Reply #1 on: July 28, 2013, 12:58:54 PM »
attach your xml and the code you are having issues with and I will see if I can find the problem.
« Reply #2 on: July 28, 2013, 01:23:51 PM »
Ok thanks Hood,
The drilling section of the 'test' file is fine but cutting out the square doesn't happen. The 'x' axis moves fine but the 'y' axis doesn't move at all. Although it shows moving on the dro.
Cheers,
Gav
« Reply #3 on: July 28, 2013, 01:31:17 PM »
Have sent you a private message.
Offline gavna
  •  12 12
« Reply #4 on: July 29, 2013, 01:41:53 PM »
Hello Hood,
Would it be possible for you to have a look at my program at all?
Thanks Gav
« Reply #5 on: July 29, 2013, 03:51:28 PM »
What is the problem when running that code?
Offline gavna
  •  12 12
« Reply #6 on: July 29, 2013, 04:36:40 PM »
Hi Hood,
It runs fine to the start position and drills both the holes, then moves to start cutting the square and it will run down the x axis but not the y axis. Nothing happens on the y axis at all. Then moves back to the start position.
Thanks Gav
« Reply #7 on: July 30, 2013, 02:39:38 AM »
Ok, not sure how I can test for this as the DROs are moving so Mach is certainly saying its sending the pulses out. I think I have a PCI port here that I can install tonight  and I can then hopefully scope the motor pins to see if it is definitely outputting the signals.
I notice you are in Demo mode, obviously you removed the old licence but have you tried with the new licence?
Offline gavna
  •  12 12
« Reply #8 on: July 30, 2013, 11:18:26 AM »
Hi Hood,
Yeah I have installed the new licence and it still does the same thing.
Many thanks for this you are a great help.
Gav
« Reply #9 on: July 30, 2013, 03:28:09 PM »
Ok cant find my PP so not been able to test, however if the DROs are moving in Mach then that means the driver is sending the pulses to the port address assigned in Mach. The DROs are updated from the pulses the driver outputs so it has to be sending them.
