Hello Guest it is October 26, 2026, 09:19:42 PM
Author Topic: Gcode runs with Mach2 but not Mach3  (Read 12751 times)
« on: July 27, 2013, 02:01:41 AM »
Mach3 has worked fine for a long time but it won't run gcode anymore. Jogging works, using a USB interface works and Mach2 works. I used to be able to fix it by erasing the Mach3 directory and reinstalling but that no longer works. I've tried a number of versions. I figure the parallel port card, breakout board, drivers and steppers are all OK because Mach2 works.
Mach3 tries to run a program but the motors only make noise. If backlash is enabled the motors just go back and forth the amount of backlash. It sounds too fast and the feedrate has no effect. I'm using 25MHz. The DRO flickers a little but stays the same. If I push the "To Go" button I can see it counting down. What is wrong?
Paul
Re: Gcode runs with Mach2 but not Mach3
« Reply #1 on: July 27, 2013, 03:27:15 AM »
Sounds like your motor tuning may be wrong, ie Vel and/or Accel set too high for your setup.
« Reply #2 on: July 27, 2013, 03:47:36 AM »
The tuning has been working fine until recently. In jog it will go at 100%. Also the same speed works in Mach2. On a scope the pulses are too close together and not spaced evenly. Some axes don't even try to move. Plus the DROs don't move.
« Reply #3 on: July 27, 2013, 03:51:15 AM »
Attach your xml and I  will see if I can find a problem with it.
« Reply #4 on: July 27, 2013, 08:03:18 PM »
Here it is
« Reply #5 on: July 28, 2013, 02:51:23 AM »
I have sent you a PM.
