Hello Guest it is October 20, 2026, 06:46:08 PM
Author Topic: "Another" Soft Limits issue/problem  (Read 27446 times)
Re: "Another" Soft Limits issue/problem
« Reply #10 on: July 26, 2013, 08:55:08 AM »
3.042.029
Scott
« Reply #11 on: July 26, 2013, 09:06:36 AM »
Ok thats fine.
 Can you load the standard screenset (1024.set) and see if that helps, you may have to do the steps mentioned above again.
If not try this xml.
« Reply #12 on: July 26, 2013, 09:30:40 AM »
I do not have the standard screenset so I tried your xml with my screenset.
SUCSESS !!!!
All seems to be working again.
I can not thank you enough for your help on this, it is truly appreciated.
Out of curiosity what did you change in the xml ?
I had tried changing the value of oemdro119 and oemled119 from 0 to 1 but that did nothing so I changed it back.
Once again
Thank you
Scott
« Reply #13 on: July 26, 2013, 09:41:17 AM »
I simply did as I said above, disabled home inputs in  ports and pins, homed then enabled soft limits and then went back and enabled the homes.
« Reply #14 on: July 26, 2013, 09:50:57 AM »
That is weird , I wonder why that would not work at the machine.
Again
Thank you very much !  all is well.
Scott
« Reply #15 on: July 26, 2013, 09:53:36 AM »
May have something to do with the screenset, I didnt have the Tormach one you had so had to load the default Mach one.
« Reply #16 on: July 26, 2013, 10:08:40 AM »
Hmm
Maybe.
Scott
