Hello Guest it is November 22, 2026, 07:07:41 AM
Author Topic: DC Servo Understanding / Help with Mach3  (Read 11423 times)
« on: July 19, 2013, 02:28:47 PM »
I want to use Mach3... If I have Baldor DC Servo drive for X & Y, TSD-050-05-2-U  running Baldor DC Servo Motors  BK-2250's  ....   I need help finding out how I connect these drives to a PC
To run Mach3...
1. do I need a breakout board... if so what can you recommend?
2. Do I basically have to go from PWM to Step/Dir ???  with a breakout board or something?  or is there a board that does PWM from Mach3...
People are telling me I lose "real CNC" or I am not doing "real CNC" with Mach3 and servo drives/servo motors cause the Mach3 and the controller just do Step/Dir ...  if it's equal then I guess I don't care... but am I just buying servo to convert it to step/dir...???
help!
Brian ??? ??? ??? ???
Re: DC Servo Understanding / Help with Mach3
« Reply #1 on: July 19, 2013, 03:26:54 PM »
If your servo drives are analogue  voltage command only, ie +/-10v command and not capable of Step/Dir then you will need to use one of the external controllers that work with Mach and can control analogue drives.
There are a few,
 CSMIO/IP-A
 DSPMC
 Galil
 Kflop with Kanalog.
I use the CSMIO/IP-A on my Chiron FZ12 and it is an excellent choice.
« Reply #2 on: July 21, 2013, 10:22:18 PM »
Ok, update... I got the Baldor DC Drives that go with the motors... so should be good there...   looking at the Galil DMC-21X3 Ethernet controller ...  they offer two daughter cards to split out the axis for D-Sub connections  ...  do I need  opto-isolated I/O ?    this DMC-21X3 seems to work good with Mach3 and does the servo analog control of the drives...
anything I should look out for?
« Reply #3 on: July 22, 2013, 02:10:43 AM »
I dont know too much about the Galil and Mach, the cost of the Galil and its associated breakouts and connectors was very high so I never went down that road.
You will likely get answers to any questions you have regarding Galil and Mach if you ask on the Galil section of the forum.
