Hello
Guest
it is
November 13, 2026, 03:23:06 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
optical switch opb917bz mach lathe index
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: optical switch opb917bz mach lathe index (Read 38470 times)
turbothis
141
Re: optical switch opb917bz mach lathe index
Reply #10 on:
July 18, 2013, 03:04:03 PM »
1 yes
2 the same model switch was used before and functioned great. I just swapped the computer a while back and now need to do some threading.
3 not sure what you mean there?
Logged
Carnoustie, Scotland
Reply #11 on:
July 18, 2013, 04:24:50 PM »
3.
I am saying remove the blue wire from the input on the BOB. Connect the positive probe to the blue wire, connect the negative probe to the Gnd pin. Turn your spindle so that the slot passes the opto and you should see a voltage.
Logged
turbothis
141
Reply #12 on:
July 18, 2013, 04:54:18 PM »
I get nothing.
this is a new switch that has only been wired through the 100,000k resistor for the red wire.
Logged
Reply #13 on:
July 18, 2013, 04:58:32 PM »
100,000K?
You will get nothing through that.
Put a 220 Ohm and try again.
Logged
turbothis
141
Reply #14 on:
July 18, 2013, 05:06:46 PM »
cool! I get 5.57v
what now?
Logged
Reply #15 on:
July 18, 2013, 05:12:01 PM »
Put it back to your bob and try.
Logged
turbothis
141
Reply #16 on:
July 18, 2013, 05:17:06 PM »
nope
I try all the setting combos I can think of in the port/pins but nothing seems to read it.
I swapped it with the estop to double check and the pin works?
Logged
Reply #17 on:
July 18, 2013, 05:20:23 PM »
Put the opto into the EStops input and see if it E-Stops when you rotate off the slot.
Logged
turbothis
141
Reply #18 on:
July 18, 2013, 05:21:04 PM »
I get 1.74v to the input pin when the switch is open and 0v when blocked.
Logged
Reply #19 on:
July 18, 2013, 05:23:21 PM »
Sounds like the BOB is pulling it down.
Can you connect direct to the port in some way?
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
