Hello
Guest
it is
November 23, 2026, 03:04:14 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mirror
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mirror (Read 11647 times)
wishmasterg
Mirror
on:
February 20, 2007, 10:50:54 AM »
Hi Everyone,
New user here and I"m missing something and can't find it. When using my milling machine
the text that is being engraved is being cut from right to left, I would like it to be left to right.
Can anyone give me a clue how to make this happen? I really appreciate your help.
I found the problem, I check for past postings about the same problem and found I needed to
go to config/ports & pins/motor outputs/Dir low active for x axis and check for opposite of what
is was.
Geo
Last Edit: February 20, 2007, 11:30:47 AM by wishmasterg
Logged
Chip
2,055
Gainesville Florida USA
Re: Mirror
Reply #1 on:
February 20, 2007, 11:42:47 AM »
Hi,, Geo
On the main screen next to Axis Pos Display, "Scale" click on the +1.0000 display, Enter -1.0 hit Enter key, this will flip your Axis.
Hope this Helps, Chip
Logged
wishmasterg
Re: Mirror
Reply #2 on:
February 20, 2007, 12:02:29 PM »
Hey Chip,
Thanks for the reply, I have the axis going the right direction now.
I see its going to take time to learn all this.
Thanks again
Geo
Logged
Brian Barker
3,860
Re: Mirror
Reply #3 on:
February 23, 2007, 09:29:07 AM »
To change the direction of the axis in the setup of the machine use the Homing and Limits Revers Axis setting.
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
