Hello Guest it is November 30, 2026, 05:08:40 PM
Author Topic: Mach3 motion controller selection  (Read 10057 times)
« on: July 15, 2013, 06:33:41 PM »
I have a very.. awkward problem.
I set up the Ethernet Smoothstepper today but need to change back to the old parallel port for some simple milling operations for the smoothstepper case.
But I accidentally clicked "dont ask again" on the pop-up dialog that asks what motion controller to choose from.. So its always set to ESS
(Forgot to clone the profile)
Any tipps how to set this back without loosing all settings?
Thanks a lot!
Re: Mach3 motion controller selection
« Reply #1 on: July 15, 2013, 06:42:26 PM »
When you open Mach go to the top, Function Cfg's. At the bottom of that drop down you will see reset device. Click that and when you open Mach again you will be able to choose your device.
« Reply #2 on: July 17, 2013, 11:39:18 AM »
Thanks a lot!
greetings,
Max
« Reply #3 on: July 17, 2013, 11:40:26 AM »
