Hello Guest it is October 22, 2026, 04:31:57 PM
Author Topic: Manual movement of Stepper motors w/o power  (Read 14221 times)
« on: June 15, 2013, 07:10:19 AM »
 ???Short of disassembling my ProMax 42 router, is there any way to mannually move my steppers off of the limit switches.
All of my attempts to override and jog have not worked.  Thanks for any input.
rog
Re: Manual movement of Stepper motors w/o power
« Reply #1 on: June 15, 2013, 09:28:57 AM »
Have you gone to the settings page and enabled auto limits override?  Are you able to reference the machine successfully?
« Reply #2 on: June 15, 2013, 09:42:45 AM »
Brett... I have tried have tried the "Auto Limit Override" no success.
My current thinking is to remove the stepper motors to see if I can manually move the axis off the limit switch.
rog
« Reply #3 on: June 15, 2013, 09:47:19 AM »
I have seen the auto limits override not work if the homing routine gets interrupted.  I have sent you a PM.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #4 on: June 16, 2013, 03:48:43 AM »
If Mach HAS got it's knickers in a twist, before I'd remove the steppers (seems a bit drastic) I'd be inclined a) to disable limits in ports and pins (takes 5 seconds) b) re-install Mach (takes a minute) c) disconnect the switches at the BOB (takes...gotta be less than removing steppers).
Ian
« Reply #5 on: June 16, 2013, 05:43:05 AM »
 :) Good news on this end.  With help from Brett, I got movement from my stepper motors from the first time.  I needed to enable some additional software setting.
This is a major break through.  I think I'm on the road to using Mach3.  Thanks to those who have offered suggestions.
rog
« Reply #6 on: June 18, 2013, 12:59:04 PM »
 ??? Bad News again...
Accidentally moved my y axis into its limit switch.  This has killed all movement of the machine.  Have checked the auto-Override on the setting page with no results.  Just dead in the water.  I was actually able to run a couple of programs yesterday(just cutting air).
Think I'll go take a nap.
rog
« Reply #7 on: June 18, 2013, 01:23:58 PM »
If you attach your xml I will take a look and see if there is an issue with it.
« Reply #8 on: June 18, 2013, 01:55:20 PM »
Go into Config and UNCHECK the limits for X and Y.
Restart Mach3 and you should be able to carefully back off the physical limit switches. NOTE at this point you will NOT have limit switch protection.
« Reply #9 on: June 23, 2013, 09:13:41 AM »
To expound on Terri's thought make sure that when you attempt to jog off the limit you use a slow speed and jog the correct direction. (Don't ask how I know)
