Hello Guest it is November 08, 2026, 01:32:24 AM
Author Topic: is there a specific parrallel pci card iee transfer rate i need  (Read 11209 times)
Offline nobby
  •  154 154
http://www.cnc4you.co.uk/image/cache/data/HG07%20Rev21-228x228.jpg
bought one of them
does it matter what parallel card i buy
Re: is there a specific parrallel pci card iee transfer rate i need
« Reply #1 on: June 14, 2013, 04:16:25 PM »
You may need to make sure it is capable of 5v rather than the normal 3.3v nowadays. That will depend on the breakout though as it may buffer lower voltage signals.
Offline nobby
  •  154 154
« Reply #2 on: June 14, 2013, 05:22:20 PM »
http://www.ebay.co.uk/itm/290373968884?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_6740wt_1263
well, i bought this?as it sain 64 bit system, others didn't.
when you say voltage.... I am to connect the bob to the 36 volt outlet on my power supply as the instructions?
while I am on, I did NEED a filtered socket? I though for the extra few bucks, it was worth it for the tails, now did I NOT owant a filtered one?
http://www.ebay.co.uk/itm/290687231674?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_1368wt_1025
while on again,
the manual wheel twirley doofers, do they need to ne a certain weight like a car engine front dampner, as i bought these
http://www.ebay.co.uk/itm/110927149637?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_2081wt_1025
still have to drill them to 8mm though, do i simply need to move the axis's to home the machine.
while on again, I must tell you of my balls up, have the motors fitted into cans with amphenol connectors, great and all, opened the silvered bullet non solder connectors from the old mpotors, with a large needle, saving myself 60 pounds in new 20mm by 2mm bullets -  that all went great, put them all back together with nice just short enough wireing, then realised
I just bought these
http://www.ebay.co.uk/itm/321105000237?var=510111178360&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_2856wt_1025
as I need 8mm from the original 1/4'', and you can't fit them when the housings are on........
grrrrrrr
happy days,
« Last Edit: June 14, 2013, 05:29:21 PM by nobby »
« Reply #3 on: June 14, 2013, 05:24:33 PM »
Are you thinking of using a 64bit OS?
Offline nobby
  •  154 154
« Reply #4 on: June 14, 2013, 05:26:14 PM »
I have a 64 bit vista system
« Reply #5 on: June 14, 2013, 05:29:07 PM »
Well you will not be able to use Mach if using the parallel port, it only works with a 32bit OS.
If you want to use a 64bit OS then you will need to use an external motion controllers such as those from CS-Lab or SmoothStepper or DSPMC OR Kflop etc
