Hello Guest it is November 03, 2026, 08:48:02 AM
Author Topic: feeds and speeds?  (Read 14967 times)
feeds and speeds?
« on: February 16, 2007, 09:36:54 PM »
ok so Im still getting the hang of writting programs. One of my major sticking points is picking appropriate speed and feedrates for my operation. the little wizared in Mach is a big help. but Im having a hard time finding any good literature on appropriate chiploads for veriouse cutters. I use mostly HSS endmills. and occasionaly some cobalt bits. I run full fload coolant on my machine. but lets just say Ive broken a few bits and Ive only got about 40 hours on my new cnc mill. so I was wondering if anyone could point me in the right direction on this.
thanks in advance.
chris :)
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
Re: feeds and speeds?
« Reply #1 on: February 16, 2007, 09:41:51 PM »
What horsepower is your spindle?
What material are you cutting?
how many flutes do your bits have?
What size bit are you using?
What is the spindle rpm?
Chad
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: February 17, 2007, 02:46:36 AM »
Hi Chris,
go to the Dormer website, got to the 'Product Selector 2006' page and download the technical hand book its 40Mb but it will tell you all you need to know about every type of cutting tool and condition, well worth a look.
Graham.
http://www.dormertools.com/
« Last Edit: February 17, 2007, 02:50:07 AM by Graham Waterworth »
« Reply #3 on: February 17, 2007, 02:57:53 AM »
I have a programme called MachinistsMate, it gives you some good info, check it out at http://www.wadeproco.com/
Offline PaulWC
  •  125 125
« Reply #4 on: February 17, 2007, 05:51:36 AM »
I have been using the free "Mfg Calculator" that comes with AutoEditNC:
http://www.betatechnical.com/autonc.htm
I've found that reducing the recommended Base Velocity to 35%~50% works best for my small benchtop mill (Taig).
Most Speed & Feed calculators are set for full size, rigid machines.
Paul, Central OR
« Reply #5 on: February 17, 2007, 03:29:42 PM »
I downloaded the handbook from Dormer tools. woo man what an eyeful. anyhow I read through it and still didnt come away with anything useful that  could wrap my head around. Im not looking for maximum performance just a reasonable safe working range. so I downloaded machinist mate. that little thing is great. just what I need.
and only 15 bucks. cant beat that.
thanks ;D
