Hello Guest it is October 21, 2026, 10:36:09 AM
Author Topic: Pyrography.  (Read 154525 times)
Re: Pyrography.
« Reply #30 on: January 10, 2014, 03:53:28 PM »
Jeff,
I hear you loud and clear.  ;D
John
Re: Pyrography.
« Reply #31 on: January 10, 2014, 04:09:12 PM »
Jeff,
John
Haven't I pestered you enough John? ;D ;D
Extensivly Re-worked/Re-designed/Modified Servo K2CNC KG-3925 and the Mini Laser Engraver
Re: Pyrography.
« Reply #32 on: January 10, 2014, 08:49:12 PM »
Pester away, friend.  I can take it.  ;)
I'm almost through with a test version already.    Couple of more days - hopefully.
John
Re: Pyrography.
« Reply #33 on: January 11, 2014, 11:38:48 AM »
They look great, I'm wondering if I could use a soldering tool for doing this.
  •  9,374 9,374
Re: Pyrography.
« Reply #34 on: January 12, 2014, 02:57:38 AM »
It may not be hot enough but why not just give it a try and see how it goes.
  •  9,374 9,374
Re: Pyrography.
« Reply #35 on: January 17, 2014, 01:54:42 AM »
After gaining a bit more experience this electro-engraving seems to be quite a useful process.
Re: Pyrography.
« Reply #36 on: June 06, 2014, 11:03:38 PM »
Re: Pyrography.
« Reply #37 on: October 15, 2015, 04:52:37 PM »
When I was a youngster, ( now retired ) there were " wood burning kits" for kids to use.  The hot end was VERY similar to a soldering iron. Don't know the wattage, but expect it to have been in the 60 to 75Watt range.
  •  9,374 9,374
Re: Pyrography.
« Reply #38 on: October 16, 2015, 01:04:00 AM »
Those hand tools are still available and in turn led to homemade versions, the development of the software G-Ray and a great deal of experimentation before producing very acceptable results as shown in this thread. http://www.microsofttranslator.com/bv.aspx?from=&to=en&a=http%3A%2F%2Fwww.microsofttranslator.com%2Fbv.aspx%3Ffrom%3D%26to%3Den%26a%3Dhttp%253A%252F%252Fhobbycncart.com%252Fforum%252F46-234-1
Re: Pyrography.
« Reply #39 on: January 13, 2018, 09:43:23 PM »
Hello tweakie, my name is Jose Antonio and I'm from Cuba.
I tried using the g-ray but I have a problem:
I am using for white 1500 mm / min and black 300mm / min but what I print always remains very dark because if it is white every time the speed is updated it seems that the match does not give time to reach that feedrate and it is lost.
For example if I have a line with pixels with the following feedrate sequence: F1100 F900 F1300 F1200 F1225 F1400, in fact what I get from feedrate output does not even reach 400 mm / min because it is as if it took a while to go from 0mm / min at 1100 mm / min. I know it's a problem in the match but I have no idea what it can be. I also have the acceleration of the axes to the maximum to avoid just that but nothing.
If you could help me, I'd really appreciate it.
PD: I've seen your official page and your posts in many cnc forums and your work is great. Congratulations.
Greetings from Cuba.
