Hello
Guest
it is
November 13, 2026, 11:26:47 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
CNC starts and stops vectors
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: CNC starts and stops vectors (Read 7699 times)
gene8522
117
on:
June 06, 2013, 03:10:37 PM »
I've read before that someone had this happen to them but can't remember were I saw it.
My home built CNC running on MachIII does not run the coded vectors smooth. It runs just fine then will pause for like a second or two then run but after a bit will pause again. Some times it will stop running the code two or three times in X or Y movement every three or four inches. I don't know if the problem is in MachIII or my PC controls. Seems like I had read that the PC speed may be too slow. But this problem has just started about 3 or 4 mouths ago using the same PC.
Any thoughts?
Logged
Print
Pages:
1
Go Up
« previous
next »
