Mach Discussion > Mach4 General Discussion
New people welcome !! Come in here and introduce your self!
chad:
I was noticing that as of this writing we have 2795 members and have only heard from a couple of hundred and an even smaller number of regular posters.
So if you are new around here please post and introduce your self. You could give a little on your background, hobbies , how you ended up here, whatever!
This is a site to help with mach. There is a great talent pool here already but this is a community driven site and we would love to hear from the silent masses ;)
So stand up and say hi!!
Chad
wantcnc:
I’m not new new, been around the forum for nearly a year
I am in the process of converting a Warco VMC to CNC control
The current status is that the controller has been build and only needs drives fitting
The machine is now under attack, currently machining the mounts for the motors.
I was born in Holland and moved to England somewhere in 94 for work ( headhunted)
My interest in CNC started long ago
As I helped a guy converting his lathe back in the mid 80 ties (I did the mechanical work) He used BASIC and a Apple II for control while I was still at school.
Later at the Polytechnic they got a Deckel FPx CNC centre which got used by the teachers. We where kept a long way away from it. (the last 2 years there)
I then set of in a different direction (Stage lighting electronics) so for years no real contact with CNC.
Over the last 10 years I have been more involved in the overall product design.
And thus metalwork is back on my daily agenda, this is mainly sheet metal but I also design machined and moulded parts.
I bought the Warco VMC and a BH600 lathe a few years ago to be able to make special parts and prototypes for work. I also make parts for the observatory, which I have been building for the past 6 years.
My hope is to finish the mill this year along with an enclosure for it.
The next machine on the hit-list is either the Lathe or making a brake press (CNC needles to say)
JB
ynneb:
Hi my name is Benny, the dumb name I have as my forum name is benny spelt backwards. For some reason it has stuck.
I live In Melbourne Australia. I have been into CNC for a couple of years now, and love the fact that a personal computer can drive a CNC machine. Hence my involvement with Mach3.
I have built two CNC router tables now, and get a kick out of seeing a machine that I built, actually cut something. Its a constant thrill for me. ( But then again I am easily amused. )
Graham Waterworth:
Hi my name is Graham, I am an apprentice trained engineer and have worked 30 years in NC/CNC production, I started programming G-Code in 1978 when you had to make long paper tapes that had to be read and rewound for every run if the machine.
Over the years I have programmed 2,4,6 axis lathes, 3,4,5 axis mills and all sorts of other type machines. Nowadays I tend to use CAM programs to do the hard work for me but still hand code things just to keep my hand in.
My first hobby CNC was a home built router, DOS based, it was rubbish, later I retro fitted a Warco lathe to servo control under Mach3, I am now putting the final touches to a Boxford VMC190 mill that will also run with Mach3.
My other hobby is computer programming, I program in several languages and at a good level, but not in Arts league.
I live in West Yorkshire, England.
zarzul:
Hi all,
I am not very new but new enough. I use mach3 as a hobby, just started hobby machining a year ago when I purchased a mini lathe.
I got started on CNC because I couldn't cut some of the different threads (metric) that I wanted to and I got real tired of turning those handles. I am facinated by the machines abilities after converting it. I then bought a mini mill and converted it also. I built my own drivers, power supplies and interfaces, designed and built my mounting and drive configurations.
I enjoy the friendship and community of the forums, everyone is so helpful with even the greenist of users.
My background is a former navy nuc sub sailor, electronics technician and now instrument supervisor in a coal fired generating station.
Never touched a machine before my hobby.
Another of my hobbies is scuba diving and I have been building underwater high intensity lights and video camera housings. I sell some of these to support the machining monkey on my back.
Arnie
Navigation
[0] Message Index
[#] Next page
Go to full version
