Hello Guest it is November 09, 2026, 11:56:45 AM
Author Topic: Major malfunction... starting over  (Read 7883 times)
« on: June 02, 2013, 08:50:15 PM »
PC just got too polluted could hardly run anything, all kinds of corruption, features missing here and there in this app and that..... So, I did a disc image onto an external drive, and then wiped the PC clean, reinstalled the OS, and am now putting the pieces back together...
So, seeing as I have to reinstall the program, and enter the password and all that, what then?
What files do I find in the old copy on the disc image to move over to the new copy on the PC, so that I don't have to try and figure everything out from scratch again?  IOW, all the configuration files and all that stuff?
Thanks, Mark
Re: Major malfunction... starting over
« Reply #1 on: June 03, 2013, 01:58:05 AM »
Once you have installed Mach you will need to copy over
Your xml (profile file that holds your config)
Your licence file (Mach1Lic.dat)
New Fangled Licence file if you have it. (WizLic.dat)
The Brains folder if you have any Brains made
Your profiles macro folder if you have any custom macros.
Your screenset if its a non-standard screenset and also its bitmaps folder.
The plugins folder if you are using plugins for external controller or devices.
