Hello Guest it is November 13, 2026, 09:44:31 AM
Author Topic: lLearning curve a few pictures  (Read 20714 times)
Re: lLearning curve a few pictures
« Reply #10 on: June 08, 2013, 07:02:01 AM »
I'm pretty sure the first one is the one I want, the BladeRunner, but it won't load properly.  It displays the outline of the window and the line of commands across the top, but it's completely white in the middle.  I have uninstalled and reinstalled the program SEVERAL (8?) times.
Usually, if your screen is white in the middle, your links to your bitmaps is not right. I would open up that screen set in Klaus's Mach Screen, and look at the
bitmap place holders and see where they think the bit map for that holder is.
if that path doesnt match your bitmap folder, then that is the issue.
  I would have Tom, rebuild the screen set(s) for you, and send you out a corrected one.
Scott
