Hello Guest it is October 13, 2026, 04:32:56 AM
Author Topic: Lower spindle speed needed  (Read 9616 times)
« on: May 30, 2013, 01:57:01 AM »
Hello, i have the problem, my spindle starts at 1200 rpm, because the frequency converter needs a dc signal, i switched by a relay. The relay starts at a minimum speed at 1200 by mach 3. Is there a way to change the value, so my relay switched at 600 rpm, and not at 5% auf the max speed of 24000 rpm. I need lower speed for edgefinder...
Re: Lower spindle speed needed
« Reply #1 on: May 30, 2013, 06:58:23 AM »
Can't you just use an M03 to fire the relay so the signal is on and then command a S value for the rpm?
Mike
« Reply #2 on: May 30, 2013, 10:13:27 AM »
I have seen, it is no mach problem, but tripple beast, because there a 3 pins and 4 signals, so it switches relais, if pwm is over 10%
I can only let watchdog or current reduction unplugged, then there is a pin free for directly switch relais...the mechanical edgefinder runs on 600rpm and my spindle in this configuration starts at 1200rpm, is this a problem for the edgefinder?
« Last Edit: May 30, 2013, 10:23:53 AM by Garfield »
« Reply #3 on: May 30, 2013, 10:48:02 AM »
I would check with you r edgefinder manufacturer to see what teh max speed is. I would think that 12 would be ok but what do I know.
Mike
