Hello Guest it is November 13, 2026, 12:14:09 PM
Author Topic: how was te road runner created ?  (Read 20789 times)
Re: how was te road runner created ?
« Reply #10 on: May 26, 2013, 10:26:21 AM »
The first thing you need to do is set the steps per unit correctly. I prefer to calculate but you can also do it from the Settings page, you will see a button just above the Reset on that page that is called Set Steps. Just click and follow its instructions. It will only be as good as you can measure but should get you close.
One thing however if your axis are moving the wrong way as per the link Brett linked you to then you should change that first, to do that just change the active state of the Dir pin in Ports and Pins, Motor Setup.
« Reply #11 on: May 26, 2013, 10:32:25 AM »
So how do I un-mirror or change the X axis the other two Y and Z are OK
« Reply #12 on: May 26, 2013, 10:34:10 AM »
OK
Read you loud and clear.
Thank you all
« Reply #13 on: May 26, 2013, 10:57:05 AM »
OK
I changed the active states in port and pins all is good now.
Road runner runs as should be.
Getting the hang of this with you all help.
Some times it is better to be way out to lunch then you learn more LOL
Thank you all.
Just have to do the stepping now.
