Hello Guest it is November 07, 2026, 02:16:04 AM
Author Topic: Errors and Crashing on XP  (Read 69491 times)
Re: Errors and Crashing on XP
« Reply #10 on: May 23, 2013, 03:44:10 PM »
OK, Brian was quick. It looks like we have a fix.
I will attach a zip file to this message. Unzip this into C:\Program Files\Wizards\Mill It shuold ask if you want to replace the current file, you do.
Your old desktop icon will now point to this new version.
Besides the fix for metric drill cycles, there are two new operations added- a User Gcode entry and a Tool Strategy change. There are also improvements to the g code generation.
This will serve as a test version, I hope a few people see this and try it out. I should be ready to make it a proper install kit in a few more days.
EDIT- removed the file, the full installer has been placed on the web. See  http://www.machsupport.com/downloads.php
« Last Edit: May 24, 2013, 11:48:05 AM by Ron Ginger »
« Reply #11 on: May 23, 2013, 06:51:14 PM »
Now thats service, good work Ron  ;D ill be in the shop later today and will give it a go.
cant wait to see this thing when its all ready.
« Reply #12 on: May 24, 2013, 10:26:40 AM »
The fix worked a treat. the software is running perfectly as far as i can tell including the new operations. ill test it further over the weekend and report in if i have any dramas.
thanks heaps for the help, i cant wait to see the finished product.
« Reply #13 on: May 24, 2013, 10:41:35 AM »
