Hello Guest it is October 14, 2026, 08:11:59 PM
Author Topic: Gecko 320x  (Read 49420 times)
Offline Robhi
  •  138 138
Re: Gecko 320x
« Reply #30 on: May 12, 2013, 04:30:02 PM »
yes I will have a slave one.
but there is a very important thing that I discover right now... normally, I have a pulley of 20 teeth on the motor, 60 teeth pulley one the screw. so, normally, If I write Go X 10.0 , the motor should turn 3 times, and the screw one time in order to have 10 mm, machine moves 10 mm since I have a screw of 10 pitch.
but I found that the motor turns 3/4 turn, even not one turn when I write G0 X 10.0 . so there is some thing that does not work in the step per unit  I guess.
what do you think?
Robhi
Re: Gecko 320x
« Reply #31 on: May 12, 2013, 04:33:57 PM »
Your steps per unit should be correct at 600 if your encoder is 500 line and your gearing 3:1 with 10mm pitch screws.
I presume your X is at 0 when you command that X10 move?
Offline Robhi
  •  138 138
Re: Gecko 320x
« Reply #32 on: May 12, 2013, 04:36:27 PM »
yes it was at 0
Robhi
Re: Gecko 320x
« Reply #33 on: May 13, 2013, 01:51:46 AM »
Not sure what is happening then unless the gearing or pitch or encoder count is not what you think.
Offline Robhi
  •  138 138
Re: Gecko 320x
« Reply #34 on: May 13, 2013, 01:07:50 PM »
I found some thing in the encoder that the DIP of the encoer were all of them at position 1, but in the pdf , manual of the encoder, 2 of them should be on  and the position off.
I will try it and let you know.
Robhi
Offline Robhi
  •  138 138
Re: Gecko 320x
« Reply #35 on: May 13, 2013, 03:06:44 PM »
Hello,
You are right Hood, the problem was in the encoder as you said. So I only changed the DIP switch of the encoder, adjusted the current limit of gecko 320x at only 9 o'clock  and every thing is OK.. 3 runs to achieve 10mm , so it is correct now. and also the speed. now the motor turns so fast I guess more than 1500 rpm. so every thing is OK for now.
thank you so much Hood and all the other members of the forum.
thanks again
Robhi
Re: Gecko 320x
« Reply #36 on: May 13, 2013, 03:56:46 PM »
Good to hear you got it :)
