Hello Guest it is November 22, 2026, 08:31:30 AM
Author Topic: Limit Switch Problems - BAFFLING!  (Read 41611 times)
Yodawill2000
Re: Limit Switch Problems - BAFFLING!
« Reply #20 on: February 20, 2007, 04:43:50 PM »
I had the same issue and as Hood said raising the debounce fixed it right up !!
« Reply #21 on: February 21, 2007, 08:43:00 AM »
At this point, I have several things I want to try and I have some strong suspicions based on what you all
have told me. I will try a higher debounce but my best suspect lies in the noise area. After evaluating my
wiring, I suspect that noise from the motor lines may be creeping in. I can't look at this until the weekend but
I will let you all know how it comes out. Thanks for the suggestions.
Yodawill2000
« Reply #22 on: February 21, 2007, 09:45:03 AM »
put 1100 in there and I bet ya a donut your problem is solved   ;D
I have shielded everything and a earth ground to everthing and I still had to make that tweak.
