Hello Guest it is November 13, 2026, 11:52:34 AM
Author Topic: please help before i burn the lot  (Read 24497 times)
Re: please help before i burn the lot
« Reply #10 on: April 28, 2013, 11:42:08 AM »
Likely it will be, there were several models at the time and likely different ones now.
« Reply #11 on: April 30, 2013, 07:37:50 AM »
Ok seems like keygrabber no longer (as far as I can work out) programs ipac.
« Reply #12 on: April 30, 2013, 09:48:06 AM »
A long time ago wehn I was playing with keygrabber I used the ps2 model of the Ipac if that helps.  Here is a link to a topic that you may find useful.
http://www.machsupport.com/forum/index.php/topic,1391.30.html
« Reply #13 on: April 30, 2013, 04:08:47 PM »
From memory (been a long time since I used the Ipac) all Keybgrabber does is grab the keystrokes from the Ipac and do whatever  oem code you have requested it to do, dont think it programmes the ipac.
What model Ipac do you have?
What made you want an I pac in the first place?
« Reply #14 on: May 04, 2013, 08:03:34 AM »
The keygrabber has an ipac programmer in the drop downs but can't get it to work. It seems to work good enough for now. Would use pokeys if I had to do it again
