Hello Guest it is November 13, 2026, 05:59:15 AM
Author Topic: Is my PC too slow or...?  (Read 39131 times)
Offline mbele
  •  58 58
Re: Is my PC too slow or...?
« Reply #10 on: April 22, 2013, 07:32:02 AM »
I played with lookahead and kernel frequency, but with no results. Ian, would you please, if it's not too much trouble, post your settings xml file, so I can do the comparison ? BTW. your machine is quite impressive, handling theese feeds and accelerations with no vibrations (being built from alu extrusions, if I'm seing right) - do you have build/specs thread ?
I ran test one more time with 0.3G accel, and though I cannot see that machine slowsdown/stops, I can feel it if I touch the machine frame. So, my theory about low acceleration causing CV to fail is not correct. Also, I presume that PC is fast enough, since Ian is getting good results with slower PC.
Mihael
« Reply #11 on: April 22, 2013, 08:54:59 AM »
Ian what version of Mach are you using? If I recall some versions had CV issues and some didnt.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #12 on: April 22, 2013, 12:03:37 PM »
Hi Hood, on the machine in the vid I'm using 42.20. (never got round to updating it)
Coincidentally I have an eye on CV being "the problem". (or more to the point a MYTH about CV being the problem).
When Mihael asked me to post my xml I did a quick compare of mine and his. There's basically just one difference. I notice he has "Stop on CV angles > 89.9"
Mihael please turn this off (untick it in general config) and try your toolpath again.
Ian
« Reply #13 on: April 22, 2013, 12:09:49 PM »
Well I cant try that version as it will be too old for the CSMIO that I use and regarding your Stop CV, I dont have that enabled in my profile so possibly not that.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #14 on: April 22, 2013, 12:21:44 PM »
I'll whack 43.62 on it and get back
Ian
« Reply #15 on: April 22, 2013, 12:30:33 PM »
Thanks, would be good to know. I am using 056 or 057 I think.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #16 on: April 22, 2013, 12:32:01 PM »
Yep - looking like you're absolutely right Hood. With 43.63 I get exactly the same problem.
Ian
« Reply #17 on: April 22, 2013, 12:34:52 PM »
Ok thanks, I am thinking it may be 022 or before that is needed, seems to after that version that a  lot of things got screwed up.
Dont suppose there is a chance of you trying 022? :)
Offline stirling
  •  2,188 2,188
  • UK
« Reply #18 on: April 22, 2013, 12:55:54 PM »
will do but it'll have to wait till tomorrow - unfortunately I have to go out and drink some beer!
Ian
« Reply #19 on: April 22, 2013, 12:57:16 PM »
Ha ha as good an excuse as any I suppose ;D
