Hello Guest it is November 22, 2026, 01:29:55 PM
Author Topic: Rotary tables and feed rate  (Read 25198 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Rotary tables and feed rate
« Reply #10 on: February 11, 2007, 04:45:19 PM »
Hi, Bathgate
Sent you a PM
Thanks, Chip
« Reply #11 on: February 11, 2007, 09:25:00 PM »
I find that if I run "constant velocity" on my rotary, it is wicked slow. Maybe you have that checked under "state"
« Reply #12 on: February 12, 2007, 04:01:00 PM »
Aha!! I found it.
under-Configure-tool path. theres a little check box that sais "use diameter for feedrate". That did the trick.
one problem down many more still to pop up.
thanks
