Hello Guest it is November 13, 2026, 09:39:55 AM
Author Topic: Losing Pulses at lower accelerations  (Read 26939 times)
Re: Losing Pulses at lower accelerations
« Reply #10 on: April 08, 2013, 10:05:46 AM »
10K,
I may have missed it it your posts, but what are the specs of your lead screws?  Perhaps you are asking for too much rpms trying to get faster ipms with a screw pitch that is not capable of the speeds you seek.
John Champlain
« Reply #11 on: April 08, 2013, 10:14:48 AM »
10K, in this post you will find a link to a video of a very nice machine running at roughly 758 IPM.
http://www.machsupport.com/forum/index.php/topic,22495.msg170685.html#msg170685
Offline 10k
  •  13 13
« Reply #12 on: April 08, 2013, 10:41:41 AM »
Screw pitch on X and Y is 5 turns per inch.  Steppers are 2000 pulses per rev, so 5 x 2000 = 10,000 pulses per inch.
As I mentioned, I can get the X axis to at least 200ipm with no lost steps if it's running by itself.  The problem comes in when X and Y are running simultaneously, as happens for circles.
Going from a 4A to a 15A power supply does not make any difference.
« Reply #13 on: April 08, 2013, 04:00:15 PM »
10K,
Sounds like your steppers may be limiting higher, more reliable, rpms past 1000.
John Champlain
