Hello Guest it is October 20, 2026, 08:33:50 PM
Author Topic: having a script issue.  (Read 20888 times)
« on: February 11, 2006, 09:20:19 PM »
doing a little code to zero work z. program works fine when i single step through it but when i run it from a button, not so good. here is the
here is the code.
feed = getdro(18)
if suchsignal(22) then
code "g31 z-7 f35"     'seek the sensor fast
while ismoving()
wend
sensor = getoemdro(85)  'get machine z position
pull back = sensor +.1     'add .1 to machine z
code "g53 g01 z" & pullback   'move z upto clear sensor
while ismoving()
wend
nextmove = getoemdro(85)  ' get new machine z position
move = nextmove - .11       ' set up for next machine move
code "f1"
code "g31 z" & move   ' slow sensor seek
while ismoving()
wend
ofst = getoemdro(1001)   ' get sensor height
call setdro(2, ofst)           ' set work z dro to sensor height
code "f" & feed              ' reset feed rate
end if
end
ok here is the problem i  have.  when i step through the script using the editor i works great, just like i wanted it to.
this line "call setdro(2, ofst)  sets the work dro to sensor height ,then from the mdi line i can type in g01 z0 and it will move the tool down to top of part.
when i run it from the auto zero button it won't set dro 2 to the right offset.
any ideas
thanks rob
Re: having a script issue.
« Reply #1 on: February 12, 2006, 06:41:08 AM »
I made a few changes to your code and I think it should fix you up... My test mill is down so I can't test it here:(
To get the PROBE data you need to do a GetVar(2000) = X 2001 = Y 2002 = Z
Hope that helps
Brian
feed = getdro(18)
while ismoving()
wend
sensor = getvar(1002) ' getoemdro(85)  'get machine z position //check this line
while ismoving()
wend
code "f1"
while ismoving()
wend
code"G4P.2" 'Pause to let Mach3 update //Added a line here
end if
end
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: February 12, 2006, 01:18:53 PM »
when i put in the line
sensor = getvar(2002)
i get no value what so ever when i step through that kine of code.
 and i still have the problem of not geting the right data into DRO(2)
most the time it puts in 1.6********* and oemdro(1001) is set to 1.7055
even if i take out the
  ofst = getoemdro(1001)  and just put in
  call setdro(2,1.7055) it still wont work.
this is where my problem lies the program is working other than setting the dro to sensor height so that i can
take enter a g01 z0 and move my axis to top of part.  the program works great when i step through it.
« Reply #3 on: February 12, 2006, 02:17:11 PM »
sorry first line should read is
sensor = getvar(1002) not (2002)
had a typo while reposting and could not edit
« Reply #4 on: February 12, 2006, 05:27:06 PM »
Try adding a few G4's to the program. This can give some time for the dro's to update (only need a few micro sec).
  ofst = getoemdro(2002)
code "g4 p.5"  '<-- add this line and test it
While ismoving()
wend
www.machsupport.com
« Reply #5 on: February 13, 2006, 04:35:38 PM »
thank you Brian the g4's them selves did not do any thing but the while wend statement after them did.
id there a pause statement or wait statement in the vb script.  i could not find any thing in the cypress pdf. unless
i over looked it.
any ways thank's again.
Rob
« Reply #6 on: February 13, 2006, 05:03:51 PM »
GREAT!!!
Happy codeing :)
www.machsupport.com
