Hello Guest it is November 17, 2026, 11:40:38 AM
Author Topic: Cuter Complensationn working ???  (Read 9465 times)
Offline Sage
  •  370 370
« on: March 23, 2013, 06:34:07 PM »
Was cutter compensation ever fixed? If so in what version.
And if I go to that version what other issues can I expect?
Looking back, I think there was problems with the version I'm using. 3.042.040
Sage
Offline Sage
  •  370 370
Re: Cuter Complensationn working ???
« Reply #1 on: March 24, 2013, 04:02:46 PM »
What??
Nobody Knows if cutter compensations works?
« Reply #2 on: March 24, 2013, 04:22:53 PM »
Sure but trying to describe what may or may not work and what versions may do what or not may take days(;-)
Cutter comp has not been fixed in later versions (.066/.067) That I am aware of, there be bugs with G2/3.
You would need to BACK UP in Version until you find one that is stable for YOU. But none are realy stable for doing Tool Comp with sub programming.
IF memory serves me .043.22 worked fairly well in Straight Gcode without SUBS. With subs it would do one layer into the sub then fail IF you went another Nest layer deeper in a aSUB.
Not certain without retesting, Your Milage may vary(;-), TP
