Hello Guest it is October 23, 2026, 06:54:07 PM
Author Topic: Got Probs with threading on the Lathe  (Read 30726 times)
Re: Got Probs with threading on the Lathe
« Reply #10 on: March 21, 2013, 03:54:44 AM »
Can you show me where you can see that its a demo version ?
So I can show it to my reseller .
But maybe I forget to put the licenskey in.... I will take a look on this
« Last Edit: March 21, 2013, 04:06:52 AM by Vortex »
« Reply #11 on: March 21, 2013, 04:06:02 AM »
Did you get a licence from the seller? it will have been emailed to you or him from Artsoft. If you did then you need to place it in the Mach3 folder.
In Mach you will see whether you  have the licence placed correctly as you will se your name or a serial number in the Help, About Mach....
« Reply #12 on: March 21, 2013, 04:06:55 AM »
Oh its a file called Mach1Lic.dat
« Reply #13 on: March 21, 2013, 04:10:43 AM »
I will take a look ...maybe I forget to put it in...
« Reply #14 on: March 21, 2013, 05:16:14 AM »
Hood, can you do something with the XML ?
Maybe it works better after you made some changes.
« Reply #15 on: March 21, 2013, 05:28:24 AM »
Suggest you make sure that your license is installed.
« Reply #16 on: March 21, 2013, 05:31:47 AM »
I cant do anything to your xml to make it better if its not licensed, so if you have a licence, place it in the folder then attach your xml again and I will see if I can find the issue. I dont think however you will have the pull out being so slow once licensed.
« Reply #17 on: March 21, 2013, 05:49:00 AM »
Yes Ok . I will see if the license is already in ...if not I will do it and than I retry ....Hope that´s only a issue of license
Thank You
And we will keep in touch
« Reply #18 on: March 21, 2013, 09:36:50 AM »
Hello Hood
I found the issue.
After-hours the toolchange i put in G95 and now it
works.
I normaly work in G94 modus ...
I thought that the G76 Modus changed automaticaly in G95
« Reply #19 on: March 21, 2013, 10:30:45 AM »
G76 will normally use feed per rev in a synchronised feed but as you do not have a licence then that is probably the reason it wasnt working correctly, in fact it still probably isnt working correctly as likely it is just doing a feed per rev rather than a properly synchronised move.
