Hello Guest it is November 18, 2026, 09:18:59 AM
Author Topic: G83 Random Bug  (Read 64356 times)
Re: G83 Random Bug
« Reply #20 on: March 15, 2013, 07:07:34 PM »
The random misbehaving of the Z axis in drill cyles is a VERY old bug That has come and gone several times over the years in various verisons.
Just a thought, (;-) TP
Re: G83 Random Bug
« Reply #21 on: March 16, 2013, 01:58:59 AM »
Hello TP
Thanks for the input.
If you could expand on your information I would appreciate it.
Especially the "gone" part.
Dennis
Re: G83 Random Bug
« Reply #22 on: March 16, 2013, 10:24:30 AM »
You may want to try older versions of MACh3 as some seem to not be effected.
Re: G83 Random Bug
« Reply #23 on: March 16, 2013, 12:27:52 PM »
TP
Thank you,
That is a constructive suggestion.
Dennis
Re: G83 Random Bug
« Reply #24 on: March 18, 2013, 04:45:19 AM »
Just for information,
I have not had this problem on either my DSPMC driven mill which has done 1ks of g83 holes nor my PPort driven router which has about the same number of holes in G83 and lot more G81.
Is this know to only occur on the smoothstepper or has it been documented on any other motion controller?
I have also run several different versions of Mach3 and windows from w2k to win 7.
Mike
Re: G83 Random Bug
« Reply #25 on: March 18, 2013, 05:24:38 AM »
The OP is using the PP as far as I know.
Re: G83 Random Bug
« Reply #26 on: March 18, 2013, 06:10:39 AM »
We are using 2 parallel ports through a Apollo board provided by mach motion
Re: G83 Random Bug
« Reply #27 on: March 18, 2013, 07:25:29 AM »
We don't really understand  the concept of smoothstepper.
So we don't know if we have it, or if we are using it.
If we are using it, can we turn it off somewhere?
Re: G83 Random Bug
« Reply #28 on: March 18, 2013, 07:27:42 AM »
You are connected to the parallel ports so you are not using a SmoothStepper. The Smoothstepper is an external motion controller which takes the place of the parallel ports.
Re: G83 Random Bug
« Reply #29 on: March 18, 2013, 07:31:55 AM »
Thanks Hood.
We can eliminate that then.
I have zipped up my entire Mach3 folder and sent it with the troublesome programme to Brett.
Dennis
