Hello Guest it is October 28, 2026, 09:22:24 AM
Author Topic: Brain for air valve for machine that requires air  (Read 9849 times)
Offline drew
  •  79 79
« on: March 14, 2013, 04:47:08 PM »
Ok so my HNC leaks air badly. I use a brain to open the air when ever the machine is running or spindle is on.
Also if I open/close collet do tool change or cutoff or jog. it uses the 'is running' as a trigger.
what i would like is for the air to stay on during and for 10-30 sec after any of these operations.
if you have any ideas please share them.
Thanks Drew
If I had something important to say it would be here.
Re: Brain for air valve for machine that requires air
« Reply #1 on: March 14, 2013, 07:11:50 PM »
Hi Drew,
attached a brain.
Output3 = Spindle
Output4 = Coolant
Output1 = air
hope that helps
Alex
Offline drew
  •  79 79
« Reply #2 on: March 17, 2013, 05:02:11 PM »
ok i have been working on new brain
but cant seem to figure out to select several inputs for an And or OR lobe
I know i have done this before
can someone point the way
Thx Drew
Offline drew
  •  79 79
« Reply #3 on: March 18, 2013, 12:06:36 PM »
I watched the video again
add no-op before lobe
« Reply #4 on: March 18, 2013, 07:30:24 PM »
Hi Drew,
please post which outputs do you want to turn the air on, and which output is the air.
Alex
