Hello Guest it is October 10, 2026, 06:15:18 PM
Author Topic: Unable to access Screw Mapping OR Motor Tuning from config menu.  (Read 20094 times)
I've been using Mach3 to run my home built 3axis router and suddenly today while I was trying to re-calibrate my axis (found some runout) I was
unable to access some of the items in the CONFIG menu namely:
MOTOR TUNING
CALIBRATE SPINDLE
SCREW MAPPING
I click on them and nothing happens. No dialog, no warning. Nada.
Has anyone had this problem? I really need to access those controls and I don't want to have to start from scratch.
Thanks for any help!
Craig.
Happy Making
Re: Unable to access Screw Mapping OR Motor Tuning from config menu.
« Reply #1 on: March 11, 2013, 01:47:42 PM »
What version of Mach?
Can you attach your xml and I will see if I can replicate here.
« Reply #2 on: March 11, 2013, 01:56:06 PM »
It's Mach3
Here's the XML file
« Reply #3 on: March 11, 2013, 01:57:10 PM »
Oops. Here it is for real.
« Reply #4 on: March 11, 2013, 01:58:59 PM »
What I was meaning was which revision of Mach3, you will see that if you go to Help menu then About Mach3......
« Reply #5 on: March 11, 2013, 02:00:48 PM »
Ah yes,
R1.83.027
« Reply #6 on: March 11, 2013, 02:02:37 PM »
That is almost as old as me ;D
I will load that version with your xml and see if I have problems.
« Reply #7 on: March 11, 2013, 02:03:50 PM »
Thanks Hood
« Reply #8 on: March 11, 2013, 02:07:00 PM »
Afraid I cant find it on my computer, think it was on an old drive I no longer have in. Also looked on the ftp and earliest there is 1.84 so I will try that and see.
« Reply #9 on: March 11, 2013, 02:11:23 PM »
Seems to be working fine here so not sure what to suggest other than possibly upgrading Mach to a newer version. I wouldnt try 066 as I and some others have had issues with it, so go to the ftp and use one from 057 to 062.
ftp://machsupport.com/Mach/
