Hello Guest it is November 23, 2026, 12:14:22 PM
Author Topic: Interested in Low Power Laser Engraving  (Read 22327 times)
  •  9,378 9,378
Re: Interested in Low Power Laser Engraving
« Reply #10 on: March 06, 2013, 01:10:14 AM »
Hi John, Terry,
The crystal block 3D stuff requires a wavelength of typically 1064nm (as opposed to the 10600nm of the CO2 lasers) so YAG lasers are more often used for this type of work. (This is bit of a specialised area involving reasonably costly equipment which can also be quite expensive to run).
Offline Bodini
  •  216 216
« Reply #11 on: March 06, 2013, 08:30:14 AM »
Thanks John,  I have sent you an email.
« Reply #12 on: March 06, 2013, 10:38:58 AM »
HUM I  thought I remembered them using green diode lasers for that. I have to do some more research(;-)
