Third party software and hardware support forums. > Newfangled Mill Wizard
Pointer to current version
Ron Ginger:
Welcome to the support forum for the Mill Wizard for Mach4. I expect to keep all the support issues on this forum. Im sure there will be reports on teh Yahoo group as well, but I will try to steer them here, because we can post photos, screen shots and code here to better explain problems
The product description page for this wizard is at http://www.newfangledsolutions.com/mill_wiz.php
The download link is the normal Mach download page, http://www.machsupport.com/downloads.php
sdspurlock:
I have downloaded the software several times. Every time I run the installer, I get an error 'Error opening file for writing NFS_Mill.EXE'. If I click on the ignore button, another error message pops up 'Error opening file for writing NFSMillHelp.htb' Any Ideas what is wrong?
sdspurlock:
Please ignore last post, I read the post about install problems and found the one about running the install as administrator. That worked.
Chaoticone:
Brian just uploaded a updated version. :) Everyone giving it a play should update.
Ron Ginger:
Brett beat me to it.
Yes a new version is up and it has several changes.
I have added an operation for User Entered Gcode. This will let you insert any gcode, anywhere in the program between operations. This might be useful to enter comments to document setups, or material or whatever you need. Any Gcode you enter will be displayed in the toolpath if it generates moves.
I added an operation called Tool Strategy. There are times when you want to change tool parameters, but not make a tool change- like changing feed rate, or spindle RPM, or ramp angle.
Brian changed the circle cut routine to generate spirals instead of the previous zig-zag cut. Now the tool will just keep making circles, ramping down over whatever arc length is needed to meet the ramp spec.
I changed the rectangle routine to do helical ramps down to step depth, then an arc lead-in and arc lead-out. It now has a groove option that uses teh zig-zag ramp into the work, but cuts only a grove.
Brian fixed a bug in the toolpath screen that didnt handle metric G73 correctly. This one in some systems could cause a crash.
A few other clean up kind of fixes were made.
Any feedback will be appreciated.
Navigation
[0] Message Index
[#] Next page
Go to full version
