Hello Guest it is November 13, 2026, 01:47:15 PM
Author Topic: spindle speed problems  (Read 19772 times)
Re: spindle speed problems
« Reply #10 on: February 26, 2013, 01:05:16 PM »
hi angeltech
the inverter is only set to 60mhz , i will change to 100mhz tommorrow when i go to my workshop , i don't know why i put the ratio of .60 but i thought it might be something to do with the ratio of the motor & spindle pulley diameters ? should this be set to zero  . would i get better results if i had a spindle disc with a single slot as suggested by dickeybird
robert
« Reply #11 on: February 26, 2013, 04:07:23 PM »
definately go with the single slot, mach only needs the one. Set the ratio to one.
