Hello Guest it is November 25, 2026, 02:13:58 AM
Author Topic: RESET BUTTON ( First day with mach3 )  (Read 13632 times)
« on: February 25, 2013, 01:19:21 PM »
RESET button will not reset. EXTERNAL E-STOP REQUESTED
Re: RESET BUTTON ( First day with mach3 )
« Reply #1 on: February 25, 2013, 01:30:26 PM »
Do you have any switches or estop buttons wired up?
http://www.machsupport.com/docs/Mach3Mill_Install_Config.pdf
« Reply #2 on: February 25, 2013, 01:32:41 PM »
NO
PLEASE HELP. RESET button will not reset. Status- External EStop Requested
« Reply #3 on: February 25, 2013, 01:45:24 PM »
Go to Config, ports and pins, input signals and see what the active state of estop is.  If you change it, can you reset mach?
You can not diasblae estop.
« Reply #4 on: February 25, 2013, 02:08:09 PM »
I don't have any limits or e-stops wired up
« Reply #5 on: February 25, 2013, 02:11:27 PM »
Went to Config.,ports & pins. Tried changing it nothing happend
« Reply #6 on: February 25, 2013, 02:39:39 PM »
Try setting the estop port and pin to 0.
« Reply #7 on: February 25, 2013, 06:46:22 PM »
If you set the Estop input pin to active low, it should reset.
