Hello Guest it is October 05, 2026, 09:32:57 AM
Author Topic: Button/VB script  (Read 24612 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Button/VB script
« Reply #10 on: February 21, 2013, 10:29:19 AM »
Terry - loose the line...
Code: [Select]
DlgFunc = 1  ' Keep dialog active
and change your case 2 code to ...
Code: [Select]
If controlID = "OK" Then
  LoadFIle("c:\Mach3\Gcode\" &DlgText("List1"))
End If
Ian
« Reply #11 on: February 21, 2013, 11:21:33 AM »
Thanks Ian that did the trick(;-).
When you have a spare moment(;-)
Is it possible to List files that are   *.tap  AND *.txt ?
In the list is is possible  to have a large font(touchscreen use) and a space between each line?
Thanks again, Some day I might get the full hang of this programming BUT I fear that when Mach4 arrives I will have to fold up shop. It is far more complex than the simple CB is.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #12 on: February 21, 2013, 11:31:34 AM »
well as a quick and dirty you could change the file spec filter to  *.t??
which would list all files with a 3 letter extension where the first letter is t
care to expand? what's the plan for scripting?
Ian
« Last Edit: February 21, 2013, 11:35:32 AM by stirling »
« Reply #13 on: February 21, 2013, 11:50:06 AM »
Mach4 scripting will be LUA.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #14 on: February 21, 2013, 11:55:36 AM »
Excellent!
« Reply #15 on: February 21, 2013, 12:42:41 PM »
Easy for you to say(;-) LOL
« Reply #16 on: February 22, 2013, 04:12:22 AM »
Thanks all. Now I've got something to work with.
