Hello Guest it is November 01, 2026, 12:42:25 PM
Author Topic: inch-metric  (Read 27679 times)
Offline skaha
  •  57 57
  • My first attempt
inch-metric
« on: February 02, 2007, 07:05:08 PM »
I am playing with the free version of codeshark, when I draw something, save as dxf and open in lazycam, clean it up and hit g code, when I open the g code in Mach 3, it comes up in metric, I have the Mach 3 set up for inch, is there somewhere I can get the code to show up in inches?
Terry
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: inch-metric
« Reply #1 on: February 02, 2007, 08:52:39 PM »
Hi, Terry
If your using Inch in Mach3, Check your g-code for a G21 in it, change it to G20 or remove the G21.
Use MDi to reset Mach3 to Inch mode, enter G20 on MDi line.
Hope this Helps, Chip
Offline skaha
  •  57 57
  • My first attempt
Re: inch-metric
« Reply #2 on: February 02, 2007, 10:23:04 PM »
Thanks Chip, I will give it a try.
Terry
Offline skaha
  •  57 57
  • My first attempt
Re: inch-metric
« Reply #3 on: February 02, 2007, 11:15:04 PM »
Hi Chip, I tried your suggestions, no luck, there is no G20 or G21 in the code, I tried adding G20 near start of code, no effect, I cannot find anywhere in the codeshark program to set units, maybe I can get hold of someone from the codeshark program.
Terry
Offline Chip
  •  2,055 2,055
Re: inch-metric
« Reply #4 on: February 03, 2007, 10:31:11 AM »
Hi, Terry
On your Settings Page, Bottom right, Units are thy in MM or INCH, To change click on UNITS Alt-U button and retry.
Or use MDi to reset Mach3 to Inch mode, enter G20 on MDi line.
Post your DXF and G-code file.
LazyCam deals in Units 1 can be, 1 inch or 1 mm, Mach3 determines how to treat them
Offline skaha
  •  57 57
  • My first attempt
Re: inch-metric
« Reply #5 on: February 03, 2007, 05:54:24 PM »
Hi Chip, I went to settings page, changed the settings from inch to MM and back to inch, on the top line of the run and mdi screen there is a G20, I also entered a G20 in the G code with the code editor, but the code still shows up in metric. If I use one of the g codes supplied with the program such as the road runner, no problem, it is in inches. Go figure.
Terry
