Hello Guest it is November 07, 2026, 05:10:10 PM
Author Topic: No jog control during toolchange  (Read 10031 times)
« on: February 06, 2013, 11:38:49 AM »
After switching computers and changing from XP to Vista 32bit.  I tried to keep everything in setup the same. Now when my G-code calls for toolchange, the system stops but I have no control to jog or move anything except to Zero.  I know it must be a setting but I have been unable to find it.  Any Ideas??  Thanks
Re: No jog control during toolchange
« Reply #1 on: February 06, 2013, 12:03:43 PM »
General config, top left, what tool change option is enabled?
« Reply #2 on: February 08, 2013, 06:33:04 AM »
Brett Thanks, but I have tried all the settings in the tool change options.  I have uninstalled Mach 3 and reinstalled it. I have gone through and checked every setting.  I can find no reason for this problem. I am wondering if my G-code may be flawed.
« Reply #3 on: February 08, 2013, 06:54:08 AM »
What screen page are you on? You can only jog if the screen page has a jog on/off button, or if the jog flyout is open.
« Reply #4 on: February 08, 2013, 07:04:41 AM »
I am on the run program screen page. If I click STOP I have the ability to jog. I cannot move or zero the Z axes at the toolchange point unless it stop the program.
« Reply #5 on: February 08, 2013, 03:20:56 PM »
That is how it is supposed to work.  If you are running Gcode you can't jog around.  You have to hit stop because it is still running in automatic (executing gcode)  If you need to do a special routine during a tool change (M6) you will have to write a custom macro or 2.  They will be your M6Start and/or M6End.
