Hello Guest it is September 20, 2026, 04:02:08 PM
Author Topic: Control feedrate with rotary encoder switch.  (Read 15439 times)
« on: February 02, 2013, 06:03:27 AM »
Hi Everyone,
Ive seen these 20ppr greyscale rotary encoder switches on Ebay.
10 for about $6.
I was just thinking maybe they would make a good feedrate overide control.
Has anyone done this?
Would be great to hear if it worked well or not.
Cheers Allan.
http://www.ebay.com.au/itm/10-Pcs-12mm-Rotary-Encoder-Switches-Dia-6mm-360-Degree-New-/290813008576?pt=AU_B_I_Electrical_Test_Equipment&hash=item43b5ce5ac0
Re: Control feedrate with rotary encoder switch.
« Reply #1 on: February 02, 2013, 08:32:32 AM »
Do you have a means of getting the values into Mach?
« Reply #2 on: February 02, 2013, 09:42:02 AM »
I was thinking maybe use mpg #2 input and then write a brain to control the feed override.
What do you think?
Cheers Allan.
« Reply #3 on: February 02, 2013, 01:27:22 PM »
Yes that should work.
« Reply #4 on: February 02, 2013, 02:23:22 PM »
Just did a little brain and it works fine. ;D
Cheers Allan.
« Reply #5 on: February 02, 2013, 03:50:39 PM »
You can do the spindle override the same way. Saves having to use a analog conversion board.
« Reply #6 on: March 31, 2015, 11:04:27 AM »
How did you write your brain to control the feedrate with this encoder switch?
Chad Byrd
« Reply #7 on: March 31, 2015, 05:09:28 PM »
Try this I just changed his example brain to control the SSO instead of the FRO.
« Reply #8 on: March 31, 2015, 06:14:51 PM »
Awesome!  I'll give it a try tomorrow! Thanks!
Chad
Chad Byrd
« Reply #9 on: April 01, 2015, 08:08:44 AM »
I don't have my encoder switches in yet, I just hooked in an MPG to test this.  With the MPG it goes from 100% down To 0% and moves from 0 - 1 % but doesn't do anything else.  It does this with the SSO and the FRO.  Do I need to have my calibration set differently and/or do I need to wait for those encoder switches to get here.  I have the calibration set to 1.000 Count and velocity to 100.00
Chad Byrd
