Hello Guest it is November 13, 2026, 08:06:05 PM
Author Topic: Getting Outputs from Mach3  (Read 28851 times)
Re: Getting Outputs from Mach3
« Reply #10 on: January 31, 2013, 08:22:45 AM »
Yes just use the OEM codes for the LEDs for them, similar idea as before, if LED is on then switch the output, if its off then switch it off. You could also do similar with the step increment outputs, ie if you have the following instead of what you already have
If GetOemDRO(828)=1 and GetOemLED(15) Then
ActivateSignal (OutPut1)
ActivateSignal (OutPut4)
Else
DeActivateSignal(OutPut1)
End If
If GetOemDRO(828)=0.1 and GetOemLED(15) Then
ActivateSignal (OutPut2)
Else
DeActivateSignal(OutPut2)
End If
If GetOemDRO(828) and GetOemLED(15)=0.1 Then
ActivateSignal (OutPut3)
ActivateSignal(OutPut4)
Else
DeActivateSignal(OutPut3)
End If
« Reply #11 on: January 31, 2013, 08:26:25 AM »
Then for the next part you would have
If GetOemLED(14) Then
DeActivateSignal(OuPut4)
ActivateSignal(OutPut5)
Else
 DeActivateSignal(OutPut5)
End If
EDIT
There were a few syntax errors so I have sorted.
« Last Edit: January 31, 2013, 08:34:29 AM by Hood »
« Reply #12 on: January 31, 2013, 08:36:40 AM »
Thanks Hood
I assume I would tack your  last post onto the end of the one before
like this
Else
End If
Else
End If
Else
End If
If GetOemLE(14) Then
Else
DeActivateSignal(OuPut5)
End If
Don
« Reply #13 on: January 31, 2013, 09:29:54 AM »
Yes, it may need tweaked slightly to get things exactly right, busy at work at the moment but if you dont get it running right I will have a look when I get home.
« Reply #14 on: January 31, 2013, 10:00:43 AM »
Thanks Hood
I have to go to a meeting this evening so cant look at
it any more till tomorrow so will try it then.
Don
« Reply #15 on: January 31, 2013, 11:33:24 AM »
Hi Hood
I tried running it but it didnt want to work . I was supposed to go out to a meeting  but
I found it so interesting I had to keep trying and eventualy got it working
I did all the jog increments first then did the jog mode afterwards
If GetOemDRO(828)=1Then
Else
End If
If GetOemDRO(828)=0.1 Then
Else
End If
If GetOemDRO(828)=0.01 Then
Else
DeActivateSignal(OutPut4)
End If
ActivateSignal(OutPut6)
Else
DeActivateSignal(OutPut6)
End If
Thank you so much for your help
Don
« Reply #16 on: January 31, 2013, 12:32:24 PM »
Good you got it, was a bit rushed today and was typing my replies in between loading the lathe so made wuite a few errors. What I should have done was as below, that should work, but if yours is then all is fine, there are many ways to do things in VB.
Else
End If
If GetOemDRO(828)=0.1 And GetOemLED(15) Then
Else
End If
If GetOemDRO(828)=0.01 and GetOemLED(15) Then
Else
End If
Else
End If
« Reply #17 on: January 31, 2013, 01:36:06 PM »
Hi Hood
            I appreciate that there is more than one way to write code but
as you have a lot of experience and I have very little I knew your code was
likely to be better than mine , but I wondered why it was better.
I sat looking at it trying to see what it did differently to mine , and then I
spotted it.  My code will show the increment size and the jog mode which
is what I required but of course when you are in continuous jpg mode then
increment size is irrelevent. Your code turns off the increment size LEDS when
in continuous jog but mine still showed the jog increment which is pointless
So thank you for the new code, which I will now use , but even more thank you for
the learning experience . I now know a little bit more than I did before.
Don
« Reply #18 on: February 01, 2013, 02:22:24 AM »
I am terrible at VB but usually manage to muddle through, I can envisage ways to do things easily but doing the actual VB is the hard part as I am not a programmer :)
