Hello Guest it is September 09, 2026, 10:57:38 PM
Author Topic: Dxf and Lazy turn import  (Read 35874 times)
« on: January 21, 2013, 01:37:23 PM »
Guys can any one can upload this file to lazyturn?? i just give up after 3days, all the time i have warning and opengl fault. this 2 default files that comes with LT opens fine, but mine very very simple just don`t. or maybe someone can make a code for me straight away.
Please help any one.
Re: Dxf and Lazy turn import
« Reply #1 on: January 22, 2013, 05:33:12 PM »
I couldn't open your dxf in some CAD programs but LT opened it. There is a manual for LT.
Suggest you have a read of it and not hack the program.
« Reply #2 on: January 22, 2013, 05:57:12 PM »
Both opened fine here in Vcarve Pro and loaded into LTurn as well.
« Reply #3 on: January 23, 2013, 04:38:59 AM »
Thanks For answer.
Got the manual.
« Reply #4 on: January 23, 2013, 05:30:00 AM »
Is windows7 64bit might be an issue?
« Reply #5 on: January 23, 2013, 10:07:49 AM »
It is possible, I guess, unfortunately I'm not sure. Hopefully someone else that is using 64 bit Win 7 will chime in.
« Reply #6 on: January 23, 2013, 01:00:00 PM »
ok after another hour of trying, reinstaling openGL, the file you opened with succes, i get "Warning, no appropriate profile was found.
Clearly saying, windows 7 64bit looks not to be compatible with files im working with.
I Study manual but did not found any solution for my problem.
« Reply #7 on: January 23, 2013, 01:51:51 PM »
GUYS... FINALLY I MANAGE TO SOLVE MY PROBLEM. MESSAGE: "WARNING. NO APPROPRIATE PROFILE WAS FOUND" AND "CLazyTurnView: An OpenGL error occured:" WAS COUSED BY OPEN ACTIVE DRAWIND IN AUTOCAD!!
« Reply #8 on: January 23, 2013, 02:23:32 PM »
Excellent, good for you-  :)
