Hello Guest it is September 30, 2026, 11:22:37 AM
Author Topic: Odd Z Home Invert Direction settings behavior.  (Read 11031 times)
Offline RDB
  •  3 3
« on: January 21, 2013, 12:54:40 PM »
Hi all,
I have my home direction invert turned ON for Z axis and it works when referencing home within Diagnostics or Program Run.  When going back into Configure Pokeys56E - Pulse Engine Settings the check box for Invert Home on the Z axis is OFF  ???.  I didn't turn it off anywhere.  This only seems to happen after I've done a Ref home command from either Diagnostics or Program Run n for any axis.   If I just open the Pulse Engine Settings tab over and over, the invert home box remains ticked on.
« Last Edit: January 21, 2013, 01:09:52 PM by RDB »
Pokeys 56E 3.0.45b development
Mach3 R3.04.066
Windows7
Offline borisz
  •  220 220
    • www.poscope.com
Re: Odd Z Home Invert Direction settings behavior.
« Reply #1 on: January 28, 2013, 12:25:03 AM »
We will check these and try to recreate problem.
Can you please send Mach and PoKeys configuration file to: support@poscope.com
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
