Hello Guest it is October 21, 2026, 07:05:20 AM
Author Topic: Machine hesitates then loses position  (Read 22798 times)
Re: Machine hesitates then loses position
« Reply #10 on: January 24, 2013, 05:01:21 PM »
Good to hear :)
I think you may have your backlash speed too high, I dont use backlash myself but its at 100% in your xml and maybe that is just too much. If you dont really need it however best with it disabled and to be honest on a wood cutting machine it would have to have a fair amount of play before backlash would become an issue.
« Reply #11 on: January 24, 2013, 05:08:58 PM »
I have ballscrews with anti backlash nuts on all axis'. Why I thought I needed backlash compensation is beyond me.
I never used it before, but like I said I thought maybe it was my solution to circles coming out slightly square so that's why I enabled it prior to me encountering my lost steps.
Maybe the circle thing is a CV issue. I have no troubles with any complex designs or square pockets but that is a topic for another day.
Thanks again!
« Reply #12 on: January 24, 2013, 05:14:59 PM »
Maybe just flex with the small diameter cutter? Tried taking small depth of cuts to see if its better?
« Reply #13 on: January 24, 2013, 05:40:50 PM »
I think my depth of cut is like .015 using 20% step over? Its not a big deal, I only use that particular tool path to locate a hole that I finish drill on the drill press.
« Reply #14 on: January 24, 2013, 05:50:36 PM »
Well that small a cut will not deflect anything, thats for sure :)
