Hello Guest it is November 13, 2026, 05:04:10 PM
Author Topic: CNC conversion of radial drill - Novisa TRO 65/80/2000  (Read 277372 times)
Offline khalid
  •  213 213
    • My Wood carving
Re: CNC conversion of radial drill - Novisa TRO 65/80/2000
« Reply #90 on: April 12, 2013, 12:54:41 PM »
Some more work on Aluminum.
Dimension: 750 x550mm
Thickness= 15mm
Tool Used: 3mm Centre drill, 6.8mm drill, 9mm drill, 10mm HSS drill, 10mm HSco Dormer endmill
Attached pictures are the result of 8 Hrs continuous working of machine.  We just stopped it and the remaining work shall be completed by tomorrow.
« Reply #91 on: April 12, 2013, 01:45:36 PM »
Looks like you have a very versatile machine there,  it certainly seems to be doing a decent job even though its not really designed for that kind of work :)
« Reply #92 on: April 12, 2013, 10:18:59 PM »
yes we are limited in RPM i.e. spindle . I have machined the similar parts on wood ;)
Thats indeed a sturdy machine. Now we need special bits for milling Aluminum.
Some more pictures
I've seen your router. It's a MDF machine. Not only it's made to cut MDF, it's also made of MDF :). Cutting Aluminium on it is good achievement.
« Reply #93 on: April 12, 2013, 10:22:46 PM »
Thickness= 15mm
This one looks like the ER-40 collet holder I sent to you. Did you install it with adapter sleeve in your machine?
Offline khalid
  •  213 213
    • My Wood carving
« Reply #94 on: April 13, 2013, 01:14:17 AM »
@Hood: Thank you but all credit goes to Zafar Salam.
@ Zafar Bhae.. This machine is your converted Radial Drill Machine. ;)  I shall soon post some more picture as the milling on the Radial drill is now in progress.
« Reply #95 on: April 13, 2013, 01:18:14 AM »
Khalid,
Send a sample G-code file which you use for drilling. I'll modify the drilling wizzard according to it and send it back to you.
Offline khalid
  •  213 213
    • My Wood carving
« Reply #96 on: April 13, 2013, 06:19:27 AM »
Hi ,
Some finish product out of CNC machine. We have some chattering issues on the edges but overall the quality is good.
« Reply #97 on: April 13, 2013, 11:41:04 AM »
Hi ,
Impressive work. Good productivity. Have you trained more operators for the machine yet or Mustafa is the only one operating it.
« Reply #98 on: April 14, 2013, 04:30:22 AM »
Khalid,
 have you tried doing a finish pass to get rid of that chatter, maybe something like 0.2 or 0.5 left for a finish pass on the profile will allow it to give you a nice clean finish.
Offline khalid
  •  213 213
    • My Wood carving
« Reply #99 on: April 14, 2013, 08:40:18 AM »
Khalid,
Hood thank you for the suggestion. The clamping was very poor. However, i have to left some stock to do final finish machining. Thanks Hood for the great tip. I shall remember whenever i do Aluminum or any other material machining again.
Regards
