Hello Guest it is November 03, 2026, 08:46:36 AM
Author Topic: Spindle Calibration Function?  (Read 15358 times)
« on: January 30, 2007, 11:55:13 PM »
Hello All,
I have tried to use the spindle calibration function and haven't had any success.  After I run the calibration, I  test the spindle and can't get the correct spindle speed.  Is there any one out there who has successfully used this function.  Your input will be much appreciated.
Jose
Re: Spindle Calibration Function?
« Reply #1 on: February 01, 2007, 08:36:15 PM »
What RPM are you running?
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: February 02, 2007, 12:34:55 AM »
I want to be able to control a range form 800 to 3600 rpm.
« Reply #3 on: February 04, 2007, 08:12:45 AM »
How stable is the RPM reading that you are getting?
www.machsupport.com
« Reply #4 on: February 06, 2007, 10:07:21 PM »
The spindle seems to fluctuate between + - 40 rpm.
« Reply #5 on: February 07, 2007, 01:28:33 AM »
Not sure if it will help but have you tried increasing the Index debounce setting? you will find it under Config Menu then General Config.
« Last Edit: February 07, 2007, 01:32:53 AM by Hood »
« Reply #6 on: February 07, 2007, 04:58:16 PM »
+- 40 is a big swing... you should hear that! I am with Hood, I think you are getting some false readings
www.machsupport.com
Offline DAlgie
  •  314 314
    • Algie Composite Aircraft
« Reply #7 on: February 07, 2007, 08:06:34 PM »
Not sure what you have for a spindle sensor, but you might try what I did, here's the page http://www.machsupport.com/forum/index.php?topic=650.10
DaveA
