Hello Guest it is October 10, 2026, 01:43:02 PM
Author Topic: Dolphin Lathe tool dra files  (Read 23668 times)
« on: January 12, 2013, 05:22:55 AM »
I am currently making up some lathe tool DRA files for Dolphin Turn to use in the simulations, if anyone is interested in them I can attach.
They are metric tools with different nose rads in each style, so far I have
SVJB 2020 in 0.2, 0.4, 0.8 and 1.2 nose rads
PDJN  2020 in 0.4, 0.8 and 1.2 nose rads
PCLN 2020 in  0.4, 0.8 and 1.2 nose rads
Although these are metric designations they should also work fine for imperial people, they will just have to  convert the nose rads to know what to choose.
Re: Dolphin Lathe tool dra files
« Reply #1 on: January 12, 2013, 06:37:17 AM »
Is there no end to your kindness and giving generosity?
Maybe I'll be able to use these someday as I have not yet purchased Dolphin.
You inspire me, sir-  :)
« Reply #2 on: January 12, 2013, 08:02:39 AM »
Purely selfish Dave, I am doing them primarily for myself :)
Will upload later on with the ones I have done, I hope to get some boring bars done as they are the ones that really can save crashes as you see the part being wiped out in the simulation if things are wrong :D
Offline mr.c
  •  40 40
« Reply #3 on: January 12, 2013, 09:48:48 AM »
I would also appreciate your generous offer.
« Reply #4 on: January 12, 2013, 11:01:46 AM »
Ok heres the ones I have done so far, they are all 20mm x 20mm section tools
SVJBR/L, 0.2, 0.4. 0.8 and 1.2 nose rads
PCLNR/L  0.4. 0.8 and 1.2 nose rads
PDJNR/L 0.4. 0.8 and 1.2 nose rads
Kennametal Grooving tool  A3SCR2020K0216
Seco MDT tool CFIR2525M03 with 3mm round , will do the  0.2 and 0.4 rad straights later
Plan on doing some boring bars later on this evening.
« Last Edit: January 12, 2013, 11:06:52 AM by Hood »
« Reply #5 on: January 12, 2013, 02:19:16 PM »
Ok a few more done, this is threading
 external 25 section threading tool
Internal 11mm dia size 11 insert
Internal 16mm dia size 16 insert
Internal 32mm dia size 16 insert.
« Reply #6 on: January 12, 2013, 02:21:02 PM »
Heres the threading drawings, can only attach 4 items per post.
« Reply #7 on: January 13, 2013, 06:04:00 AM »
Ok here are a few boring bars,
8mm dia carbide
12mm dia
20mm dia
25mm dia
32mm dia
40mm dia.
« Last Edit: January 13, 2013, 06:09:57 AM by Hood »
« Reply #8 on: January 13, 2013, 06:07:23 AM »
Oh and just in case you dont know, simply changing the approach in the tool selection will change it from front or back style tool, see screenshots.
« Reply #9 on: January 13, 2013, 07:19:35 PM »
Thanks Hood, and hopefully I will be able to use them. Should I create some at a later time I'll just post in this thread.
