Hello
Guest
it is
November 23, 2026, 08:09:14 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Z zero plate
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Z zero plate (Read 8703 times)
woodguy7777
75
Z zero plate
on:
January 10, 2013, 11:11:15 AM »
when using my z zero plate i find alot of pressure is placed on the plate before the z zero is activated.
this shows up more when using v bits.
is there some way of making the z zero routine more sensitive.
thanks paul
Logged
Picengraver
343
Re: Z zero plate
Reply #1 on:
January 10, 2013, 01:22:27 PM »
Paul,
I use 1/8" v-bits all the time and have not experienced what you describe. Are you using too high of a feed rate? I use 5 ipm.
john Champlain
www.picengrave.com
Logged
www.picengrave.com
BR549
6,965
Re: Z zero plate
Reply #2 on:
January 11, 2013, 10:36:41 PM »
It is not the sensitivity of the plate but the Speed and accelleration rate that you are using for the Z. The faster yoou feed and the slower the accelleration rate is the MORE over travel you will see.
Just a thought(;-) TP
Logged
Print
Pages:
1
Go Up
« previous
next »
