Hello Guest it is October 25, 2026, 11:04:17 AM
Author Topic: Probing Wizard  (Read 61724 times)
Re: Probing Wizard
« Reply #20 on: April 02, 2013, 04:02:50 PM »
Cleaning up some old macros and making a new Probing wizard.
TP,
What happened to the Probing/digitizing Wizard? I could not find it in the toolbox download. There was lathe and 4th axis, but not this one.
Thanks. Jeff
Extensivly Re-worked/Re-designed/Modified Servo K2CNC KG-3925 and the Mini Laser Engraver
Re: Probing Wizard
« Reply #21 on: April 03, 2013, 08:53:30 AM »
OK WHICH one are you referring to ?
IF it is the 3d digitizing wizard it was removed from the site. Due to changes in MAch3 it no longer worked correctly.
Re: Probing Wizard
« Reply #22 on: April 03, 2013, 08:59:22 AM »
It's the one you posted a picture off at the start of this thread.
Thanks. Jeff
Re: Probing Wizard
« Reply #23 on: April 03, 2013, 09:19:55 AM »
Jeff still cleaning up and testing macros for that one. The basics are done .
Re: Probing Wizard
« Reply #24 on: April 03, 2013, 09:48:00 AM »
Thank you for all your hard work on the wizards and will look forward trying that one out.
Jeff
Re: Probing Wizard
« Reply #25 on: April 03, 2013, 09:56:26 AM »
Ditto's !
Thanks TP,
Russ
Re: Probing Wizard
« Reply #26 on: April 20, 2013, 08:30:03 AM »
TP, any update as to when you will make available the ProbeMasterV101 wizard?  It has couple routines that I need that are not in the current wizard I use.  You do great work.
Re: Probing Wizard
« Reply #27 on: May 11, 2013, 11:40:01 AM »
Just a bump to learn the status of the wizard.
Re: Probing Wizard
« Reply #28 on: June 23, 2013, 06:38:15 PM »
OK time to start work on the wizard again. So far this seems like a clunky process from a wizard. What it will do is write the Probing G code to Mach3 to process. A screen set makes more sense.
You thoughts, (;-) TP
Re: Probing Wizard
« Reply #29 on: December 19, 2013, 08:29:02 AM »
TP, have you managed to get this working again?
