Hello
Guest
it is
November 25, 2026, 05:43:33 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
4 th axis rotation
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: 4 th axis rotation (Read 34356 times)
gtonini
25
4 th axis rotation
on:
January 05, 2013, 10:37:06 AM »
Hi
I' ve built my 4th axis rotary indexer not sure what I did wrong when I go into mdi and type in g0 a45 the indexer rotates full circles
not the 45 degrees. Ive specified. I saw somewhere on here to specifiy my a axis as rotational in general config but i cant find that setting any ideas please.
Gary
Carnoustie, Scotland
Re: 4 th axis rotation
Reply #1 on:
January 05, 2013, 11:51:24 AM »
Multiply the steps per unit by 8 for the A and see if that helps.
gtonini
25
Reply #2 on:
January 05, 2013, 11:58:05 AM »
Just a question why would you multiply by 8 ? If I have my stepper driver set to 1/16 wouldnt it be 16 ? Just asking ?
Gary
Reply #3 on:
January 05, 2013, 12:00:53 PM »
You said it moves 360 degrees when you command a move of 45degrees. That means it is travelling 8 x too far so your steps per unit are 8 x too small.
gtonini
25
Reply #4 on:
January 05, 2013, 12:33:44 PM »
That changed it some my biggest problem is that I dont have any documentation for the motor I'm not sure if it is 200 steps per revolution or not is there any way to figure this out ? Thanks for your help !
Reply #5 on:
January 05, 2013, 12:57:34 PM »
Tell me a little about your setup, is the motor direct coupled to the rotary or is there gearing ? If geared what amount?
gtonini
25
Reply #6 on:
January 05, 2013, 04:38:09 PM »
I'm using a drive belt with 2 pulleys it is a 40 to 1 ratio .
Reply #7 on:
January 05, 2013, 04:45:11 PM »
Ok so in a rotary axis with 200 step per rev stepper and 1/8 stepping it would equal 177.7777777 steps per unit, for a 0.9 degree stepper( 400 per rev) it would be 355.555555
Meant to say the rotational axis setting is on General Config page.
gtonini
25
Reply #8 on:
January 05, 2013, 05:14:44 PM »
How should that setting should be set at ? I tried the numbers you mentioned . If I tell the machine go a45 I not sure how many revolutions the chuck rotates . I think the motor has some sort of weird steps per revolution number. I have my stepper driver set at 1/16 steps . Is there any way I can use the calibration tool in Mach 3 to set this up?
Reply #9 on:
January 05, 2013, 05:28:21 PM »
If you have 1/16 setting then you would need either 355.5555 or 711.1111111 steps per unit.
Also make sure it is set as a rotational axis on Genral config page.
Print
Pages:
1
2
3
Go Up
« previous
next »
